That's reasonable.
Here's my "gut":
The TRAC/VSC/ABS systems have been so reliable.....my guess is it's something mechanical causing the system to kick in. What? Have no idea. End "gut".
That's reasonable.
Disagree. Driving a disabled 2000+ makes it a 98-99 short only ABS. What Spike reports sounds more dangerous than not having just ABS.
John -
You, me, and everyone else here cannot be 100% certain of what the root cause is. It may in fact be that the ABS has nothing to do with the cause but is instead the only thing keeping an inexperienced driver on the pavement. Again, diagnosing such a potentially dangerous problem over the internet and then telling someone to disable a safety system is bad advice.
Jason
Second this, but agree with everyone else, the truck should not be driven further until the problem is diagnosed and repair. It is an accident waiting to happen.
None of us can ever be certain of anything through this forum. But based upon the information presented, if you gotta drive the truck to the dealer or wherever, in my opinion, the safest way to do that is with the ABS fuse pulled.
rich
Please tell me what failure (other than one in the VSC system itself) would cause the VSC system to become active while cruising on a straight road without the brakes applied in perfect weather? Now remember, not once has it gone off while driving around curves, and the vehicle performs normally otherwise. I don't believe the VSC is saving anyone in this case. I believe it is the culprit.
rich
Certainly, pretty much any failing mechanical or non-VSC related electrical component that could affect wheel speed. System senses an issue with wheel speed and then reacts accordingly to compensate. If this were the case then disabling the system would be detrimental.
Including after adding N74L shocks.Well, he tightened them.
I think it should be acknowledged that MoJ was right, albeit for the wrong reasons, when they opposed pulling the ABS fuse.
With the decision making this friend of Spikes has previously exhibited, I have no trouble envisioning her pulling that fuse and then getting straight onto the highway, where the issue Spike discovered would have also put her in danger.
Well, now we all know - disabling a safety system that (as far as we know) only ADDS to the overall safety of the vehicle without being a CRITICAL safety gadget - may not be the wisest option.
We all thought the ABS system rode transparently on top of the brake system, but we (Spike) discovered it is an integral part of that system.
... and that's one to grow on...
-LX Pilot
On the whole, yes, we still don't know what happened.
However, loss of the brake system was not a previously reported symptom - having its first occurrence only after Spike pulled the fuses.
Post hoc ergo propter hoc.
Ah....If you're pointing at me, I never suggested diabling it. No spin dude.
After they figure out the original problem, it would be interesting to pull them again and see what happens - unless one of us wants to try it....
NOT IT!
-LX Pilot
