TMPS woes for me, need help. Had one sensor going out so I bought a complete set of Denso's from Rock Auto for a 2015 LC, part #Denso 5500106. Took them to Discount Tire and they installed them but were unable to sync up w/ LC. Their suggestion was to buy a new set directly from them or go somewhere else. I figured, no problem, I have Techstream and will just change codes at home. Get home in about 15min (5 miles) and hook up TS only to see that the new codes are listed correctly in TS but there are no readings from the new sensors, WTF? Is there something else I need to do to get these sensors working? Tried resetting the TPMS button to no effect. This shouldn't be so hard...
This. There is a bright red tag on each new sensor saying it’s necessary. Any time I haven’t done it, problems. Do the process, they work.You may need to “awake” the new sensors. There is a process of rapidly deflating the tire and then inflating it back up that Denso says may need to be performed with their new sensors. I have never needed the do this when swapping wheels/tires but is something they advise. I use Carista to program my TPMS and it works flawlessly. The only issue I have encountered was user induced when I kept putting in the wrong TMPS ID code.
I’d get a valve core tool then put a jack under each corner while you let all pressure out, then reinflate. They should work after that.
