i use the lower rad hose heaters, they seem to do the job very well even at -20C with a wind chill of much lower...canadam said:I'll find out if my truck has a block heater early next week when it lands. If not. I'll be installing one.
I'm not sure the part number needed, does anyone know ?
The truck is a 90 Prado, 2.4L Turbo.
Thanks for your help !![]()
lowenbrau said:Just a data point. One of those tank type heaters cost my LJ73 two heads and a turbo. Make sure you install it right. Personally I'd only trust a heater with its own pump or a frost plug style heater. I believe we discovered that the OEM one is actually made in Canada by ?Temco? .
Chang-kuao-lo said:What are "lower rad hose" heaters?
crushers said:exactly, the hose size on a 2LTE is 1 3/8ths. the 1 1/2 is a tight PITA fit and the 1 1/4 is just a bit loose, i use the 1 1/4 and it seems to work very well. the 2LTE started at - 20C recently with a wind chill much colder on the first turn of the key...
brownbear said:vaseline make it fit, generally a comment for many things.........![]()
dry rubber is never a good idea. for uuummm inserting things.........
this is tech.
canadam said:And Vaseline is never a good thing to use on rubber.
this is tech too.![]()
