MaddBaggins said:Airbags!!?? What's that?
... Mother-in-law
(Now I'm in trouble
)LR_RESQ said:... Mother-in-law
(Now I'm in trouble
dclee said:That's strange, our dealer has no knowledge of this "exchange" program, and from what I've been told by both local dealerships as well as MBCA members and MBNA certified techs is that Mercedes recently extended the "expiration" time to 14 years because their airbags simply were not going bad. Don't know any of the technical details of this.
Our `86 190E has a driver's airbag (first car to have one, I think) and the SRS light has never stayed lit after the startup check. Wonder if the thing still works???![]()
Beat me to it! What's an airbag? Real trucks don't need no airbags! offroadkid said:Yes it does. When the key is first turned-on, the air-bag system is running a check. If the light does not go off, it means there is a problem, eg. high resistance, open circuit, short to gnd.
I'm a Chrysler mechanic, and we see alot of airbag lights. Most of the time it's in the Town & Country minivans, and they are due to an "open squib" in the clockspring which is in the steering column behind the steering wheel. The clockspring allows operation of the steering wheel mounted controls such as the cruise, or radio while turning the wheel. Chrysler actually has a recall on these. CHRYSLER HAS ALOT OF RECALLS!! If under 70K miles, it gets replaced. If over 70K, we check for DTC's. If no DTC's, it doesn't get replaced.
I've replaced a handful of passenger airbags in the PT Cruisers for open circuits, and there's also alot of Sebring Convertibles with intermittent airbag lights which is due to corrosion in the connector for the driver's seatbelt tensioner. This is the driver's side buckle which incorporates an explosive device that cinches the buckle in an impact, pulling the belt tighter against the occupant to keep them against the seat. Chrysler's fix for the corrosion is to unplug the connector, clean the terminals and apply some dielectric grease.
As for checking airbags every 10 years, that's something I've never had to do. I too have seen the warning label on my sunvisor and have wondered how it would be checked? I guess you could disconnect the battery, and unplug each airbag connector and check the resistance. but again that's what the Airbag Contol Module is for.
clownmidget said:Eric - for someone that has Moderator status and over 5 posts per day maybe you can assist by not re-starting threads that have been thoroughly addressed and try the Search function. It is amazing what "airbag" and "check" will produce in the 80's tech.
(https://forum.ih8mud.com/showthread.php?t=33616&highlight=airbag+check)
Mike R
