Toyota Buggy
Turn key buggy, anyone that wants a well built and capable rig here it is.
Front Axle:
85 Housing, full gusset with added trusses
FJ80 HP diff
4.10 gears
Full spool
30 spline Longfield axles
ARP hub studs
FJ80 Drive flanges
Marlin Diff Armor
Full hydro steering, single ended ram
Rear Axle:
85 Housing
4.10 gears
Disc brakes
Full spool
Marlin Diff Armor
Trans and tcase:
G54 with dual cases
MC07 Marlin adapter
2piece front driveshaft with carrier bearing for flat underbelly
boat sided full belly skid
Motor:
'84 22R
Approx 10k since full rebuild
225 Impco Propane Mixer with dual tanks
GM 1-wire alternator
PSC hydraulic pump
Doesn’t leak oil, smoke, or make any noises.
Suspension:
14” 2.0 Fox Air shocks
.375 wall 2” o.d. lower links with R.E. joints
Poly Performance link bracketry
Rear Currie Anti-Rock sway bar
Suspension works and cycles excellent
Tires and wheels
39.5 Iroks on 15x8 DIY beadlocks
Tires are approx 95% tread
Also spare wheel and tire, tire has 100% tread but is tubed
Other stuff:
Kirkey seats
5 point harnesses
Warn RC 9.0 winch
Wilwood clutch and brake assembly
Removeable steering wheel
This buggy was completed in May 06 and was probably ridden 15 times since then. This buggy is easy to work on, it uses all Toyota parts except for the aftermarket parts listed. There are no frills on it and nothing complicated in it’s design but at the same time works exceptionally well. It is turn key ready to ride. I have several spares that I will include with it, driveshaft, axles, ect.
Located in Kingsport, TN
$11,000 (no trades)
4235718216
George, is that the buggy that wheeled with us at gray rock last year? If so, it did great - nice rig!
I assume full tube so no chance of getting a tag?
OOOOOHa...cooool, I liiiike, I neeeed, I waaant! Well maybe I don't neeeed!:doh:
Oh well 2 outah 3 ain't bad....but not enough to get the wife on board:doh::doh:!
