Towing/ Camping /Trailers
I always had 2 people in there with me. Condensation mats are a deeply discussed item on expo portal.
Not denying being a knuckle dragger, I am from Kemper County.
@pmccraney, If welding a nut on fails, soak with Kroil, drill hole and see if you can get it out with an ez out and some heat. I don't know what diameter the broken bolt is but I have ez outs up to 1/2".
PMC,
I can weld it for you. Can you get it to my house?
@dnp Some other cold weather tips for staying warm:
  1. Use Buddy heater to preheat your environment, even if you don't leave it on all night. Unzip your bags so the heat reaches inner fabrics.
  2. Change your clothes before going to bed. Use quality synthetic, light- to mid-weight base layer garments to sleep in and a fresh pair of wool based socks. Nylon based socks hold moisture (moisture is the enemy in cold weather). Cotton just doesn't hold heat at all.
  3. Wear a light weight synthetic stocking cap or use a small blanket to pull over your head if you don't like to zip yourself up like a mummy.
  4. Throw a couple of pocket warmers into your bag too.
I bet i can set up my RTT in just about the same amount of time it takes to deploy that fully-overlanded hammock system!
Just went all Ninja on the possible Friday night rain camping.
No doubt whatsoever.
I'm Eno ninja just because I sleep so well in it.
If I had more people going I'd take my fully pimp trailer with RTT but with it just being me I'm going Eno.
I have had a few guys bail on awning purchase......so if anyone has an interest I got an updated shipping quote and we are now sub $800 with 6 buyers. I think I have 3 to 4 firm.
I would be all over it, but I need a roof rack first. Sort of like buying a saddle without a horse. However, if that price is "shipped" and you get really pinched, then I might do it and hold it inventory.
By the way, thanks to all for trailer wisdom. It was a battle but we got it done. High heat and then cut a slit in the extruded portion of the bolt (which u can see in the below pic) and then backed it out with vice grips on flat head screwdriver (which you can also see on table). Threads of the bushing totally in tact :)
