yup. 34.3”IIRC you have pretty large tires on your cruiser?
How did you get that display on the truck display?Works on 2013-2015 with 6 speed too:
The blue ring indicates lockup in the display that says “gear”.
You’ll get better gas mileage when locked up, but you likely stay locked up on the highway 95% of the time. Unless you’re accelerating to pass or climbing a slight grade, the TC is already locked. In most cases you’ll get better mileage with the TC unlocked in a higher gear than locked in a lower gear, so if the transmission downshifts one gear instead of unlocking, your mileage will be worse.I lock the converter up and if I'm going to on the highway for 7 hours that has to impact the mileage. Any improvement is welcome. I don't care about trans temps when I'm not towing. I got the trans cooler to keep temps down when towing.
It’s an aftermarket Tesla style Android head unit.How did you get that display on the truck display?
Nice.It’s an aftermarket Tesla style Android head unit.
Is that an easy upgrade?It’s an aftermarket Tesla style Android head unit.
I wouldn’t call it easy but it isn’t really that hard. Being familiar with Android (I wasn’t) would help. Lots of info here on this:Is that an easy upgrade?
forum.ih8mud.com
There is no separate transmission ecu. It’s a single PCM that has maps for both engine and transmission and it’s absolutely tunable with VFTuner right up to 2021 trucks. HPTuners can tune up to 2015 200’s afaik.IIRC you have pretty large tires on your cruiser?
This may very well be one of the consequences of large tires. The vehicle ECU doesn't understand the tires, and sees it as additional load. When combining tire load with towing loads, the increased of both is such that it's not allowing the transmission to get into lockup.
As we still don't have proven ways to retune the transmission ECU, though we might be close - @skrypj ...
Perhaps this lockup ECU might be a fix? The other known way to resolve this at the moment is to re-gear. The 8-speed guys will want a 3.9 form the pre-2016 cruisers.
With corrected gearing on mine, I can see it readily lockup in all upper gears once I'm in cruise and the load is low enough. Normal to see it unlock on coast or engine braking.
They also have inputs for tire size and axle ratios in the tuning.
I don’t. I have not messed with them or flashed my truck with VFTuner yet.Do you know whether these inputs have a tangible impact on how the transmission shifts?
Weird. I occasionally get lock up in 4th when towing and a lot of unlocked 5th and 6th. When I rarely choose 7 or 8 when towing, I also see it unlocked when coasting downhill and maybe half the time under any load (this is hard to say since it downshifts with the slightest pedal pressure.
Yes but I believe the 6 speed is usually locked in 4, 5 and 6. Your 4th gear is almost identical to my 5th. So at least on flat ground or moderate hills you should be locked up most of the time.Well, you have a different vehicle than mine.
Mine is an 8 speedYes but I believe the 6 speed is usually locked in 4, 5 and 6. Your 4th gear is almost identical to my 5th. So at least on flat ground or moderate hills you should be locked up most of the time.
I quoted you in a different post.Mine is an 8 speed
You’re right. I’m not paying very good attention or maybe I just think everything is about meI quoted you in a different post.
I had the Cruiser Brothers Torque Converter Lock-Up Control System and transmission cooler installed on my 2013 200 Series.
The lock up feature is great . Engine braking is just like having a manual transmission. Where I would have to constantly hit the brake when downshifted to slow down I do not have to do that when locked up.
With the trans cooler , the transmission runs about 10 degrees cooler than before. I did one test towing my off road trailer the converter locked up and the trans ran about 10 degrees cooler that usual.
I'm curious to see if there is any mileage improvement locked up while on the highway. I think these upgrades are well worth the money.
4WD Transmission And Driveline Products - Terrain Tamer
Terrain Tamer 4WD Transmission & Driveline Parts for 4WD Vehicles ✔ +50 Years Engineering Parts ✔ Fast Delivery ✔ All Makes/Models | Order Onlinecruiserbrothers.com
I have not done any real testing but a short test showed lower trans temps and the engine braking is great.What difference does it make on trans temp?
Going across the Mojave with a trailer my trans was from 198 to 204, mostly 180's and 190's
My 8 speed seems to lock in gear when I run in the "S" mode, like S2 seems to lock in 2nd when going down hill. I don't think the torque converter lock is for the 8 speed.
“S” mode will lock out gears above the number you select, but afaik the transmission will still downshift to a lower gear automatically if you push down on the pedal enough to trigger it.What difference does it make on trans temp?
So do, some don't. I remember a Ford my parents had in the 70's. Was a V8 (4.9L) with a Borg-Warner auto. If you selected '2', that was all you got, right from the start.“S” mode will lock out gears above the number you select, but afaik the transmission will still downshift to a lower gear automatically if you push down on the pedal enough to trigger it.
Mine won’t shift down to first unless I’m going like 10mph though
