Tool for removing screws on engine plate???
SC
Does anyone have an idea on the best way to remove? It seems impossible to find a 5/8 flat tip. I need to remove to replace the gasket behind. Thanks All.
They're staked. They come out easily if you grind out a tiny bit in that area where the plate steel is pushed into the screw slot. A Dremel works well. You might even be able to clear it by tapping a sharp flat screwdriver blade outward where the slot meets the plate.
Replace with 90149-10001.
attachment.php
Will give the Dremel a shot. Thanks
After I "unstaked the stakes" I used the Dremel to make a decent 5/8 blade screwdriver out of an extra cold chisel I had.
Easy Greasy.....done
Thanks guys!
