Helicoil timing plate flathead screw
Madison, WI
Hi all,
Is it possible to use helicons in the tapped holes on the block for the screws that hold the timing plate on?
Hi all,
Providing there is enough material for the Heli-Coil. If you lookup the size you need you will find the spec's.
Helicoil is like a slinky, it could work but you will need to use lots of sealant is my guess if it in the cooling jacket' pressure zone, Options:1 make your own threaded bushing inside and out with a flange; 2 just tap it to the next size bolt either metric/sae. Maybe a nutzerk?
I had one on a side cover that was bad. I went up 2 or 3 sizes, screwed in a piece of bolt, peened it in place, then D&T back to origional size.
Timesert/keensert sealed with JB would work better than the helicoil.
