pilotsareplanecrazy said:
Would it put too much strain on the stock electrical system...
It depends.
Simple answer is that if your alternator has sufficient output for the loads you wish to run, then you're not straining your electrical system. However, if your alt does not produce enough amps for the loads(s) applied, then your battery will do it's best to make up the difference. (A battery can produce lots of amps, but not for long - eg startup.) If the battery gets called into play, then you'll see a voltage drop, and the longer you keep the load applied, the greater the voltage drop. Eventually if you keep this up the battery will be dead.
Your stock alt is 80amps, but that's max output, not at idle. It's probably 1/2 that at idle. When will you run these additional accessories? What amps do they draw? What else will you have running?
I'm sure that if you are mindful of the different loads you "could run" off of the stock wiring and the second circut box, you can make this work just fine w/out "straining" your electrical system. You'll need to keep in mind what you are running, and observe the volt meter. If it drops, and stays down, you have too many loads on the system.
Also, all of the above assumes that you've done a good job in installing the second fuze box. Clean connections, good ground, proper fuzing, etc.
If you post up the amps of the items you want to run, it might help a little.
