Half tank of gas? 100 miles/9.5 gallons = 10.5mpg? You need to lay off of the skinny pedal.![]()
I drive slow, this thing is a gas hog.
i'm not sure i'f i'd say the inside is "waterproof" but definitly water resistant. just dont try to hose down the switchgear, i'm not sure how that would hold up.![]()
. . . the visibility factor. Have had this long enough to know my blind spots . . . I almost ran into because they were in a blind spot. Had one hell of an "OH S**T" moment in Monterey last December. Make sure you've looked when you make your lane changes. Take the extra time and you should be OK.
Recommend getting rock rails rather than foot rails. Make sure the rock rails aren't modified with steps. Cuts down on your clearance. Those are on mine because the overall deal was too good to pass up. Debating whether or not to cut them off. Depends if the rails are truly load bearing. One of the things I was naive about before buying.
The fuel economy has ranged from 17-22, averaging 18.5 mpg on Premium Fuel. I believe it gets better economy on that grade.
What does the FJ weigh? Is it about the same as the 4runner? I get 15 mpg with my LX470 on premium. I use to get 18 mpg on my 2004 4runner SE V8 on regular which Toyota recommends using in the V8 4runner.
According to the Toyota web-site:
http://www.toyota.com/fjcruiser/specs.html?s_van=GM_TN_FJ_SPECS
4WD FJ's are just under 4300 lbs, and ...
http://www.toyota.com/4runner/specs.html?s_van=GM_TN_4RUNNER_SPECS
4WD 4runners are anywhere from 4300 to 4530 lbs depending on configuration.
The LX470 is around 5600 lbs. You would think there would be a bigger difference in MPG. I know both are way quicker then my LX
My brother in-law has a Full sized Ram 2500 with a Turbo Diesel engine. It gets about 22 MPG.
Fuel efficiency has more to do with torque, gearing, and overall vehicle design then it does with weight. If you know your laws of inertia, you'll know that weight can be a very relative thing.
I think he gets that kind of mileage because of the Cummins Turbo diesel. If he had a Hemi in that Dodge he would be getting 8-10 mpg. Do you work for the government![]()
