SOLD TN - '99 100 series w Rear Locker
Year
1999
  1. 100 Series
Mileage
151000
Color
Black
Selling my 99 TLC with 151,000 miles. Black with tan interior. I have kept it stock so it is a clean slate for the next owner. Asking $16,900 and in no hurry to sell.
It has spent all its life in FL then TX and now TN. It is in excellent mechanical condition. All electronics and drive train components run flawlessly (See the maintenance history). Clean undercarriage (very slight surface rust - see pictures), clean Carfax, tall stack of service records, drives and rides excellent, no leaks or noises. AC runs cold and automatic climate control works like new in front and rear. Heated seats work as well. Power windows, sunroof and rear vent windows all work. 3rd row seating included. Radio works fine and antennae motor works but I traded it out for fixed mast.
Transparency: Paint shows it has spent time in southern sun and clear coat is fading on driver side front fender (see images). Paint chips have been touched up but paint is not ready for the car show. Front seats are covered with duck cloth covers which are very durable but rear leather in good shape. Driver Power Lumbar doesn't work. Sunroof works fine but you have to toggle the switch to stop it between close and tilt.
Maintenance History:
By previous owner completed:
- Synthetic Oil Changes
- Timing belt and water pump
- OEM Serpentine Belt
- New Battery w 3 yr Warranty
- (4) OEM Shocks
- Hood Shocks
- OEM ABS Pump
- Calipers Pads and Rotors in Front
- Rotors and Pads in Back
- (4) New Michelin LT 275/70r16 Tires
- OEM Denso AC Compressor
Maintenance preformed during my ownership at Cool Springs Automotive (Toyota Master Mechanics): 2019 ~121,000 miles to current
- New Leather steering wheel wrap
- Rear hatch struts
- Cabin Air Filter Changed
- Fuel Filter Changed
- Radiator & Thermostat Replaced
- Tune Up - 8 Iridium Spark Plugs
- Denso Direct Ignition Coils (8)
- CV Boots (2) Replaced
- Front Differential Fluid Service
- Heater Tee's Replaced
- All Fluids Exchange
- Transfer Case Service
- Rear Differential Service
- Timing Belt (tensioner, Idler Pulley, water pump) (2nd TB change)
- Camshaft and Crankshaft Seals
- Cooling Fan Pulley Bracket
- Fan Clutch
- Thermostat Housing & Cover
- Bypass Hose / Water Bypass Hose
- Regular Synthetic Oil Changes
Other additions:
- LED interior Lighting and Reverse lights
- 3M wrap of the side trim
More Photos to come of the interior etc.
Hi there - I'm interested. Am local to Nashville and would love to take a closer look at this vehicle. Just sent you a message.
