I recently noticed while under my truck swaping rear diff oil on my new (to me) FZJ80 that the tow hitch is not your standard 'Y' shaped hitch assembly bolted to the frame. Instead, it has a wide 'L' bracket bolted through the cross member directly behind the bumper, then the receiver is welded to the 'L' bracket. Is the cross member strong enough to tow, or should I replace with a 'standard' hitch?
You guys are Awesome! Let's go wheelin'
