Tires, Tires, Tires...
Colorado
Thought this might be a good thread to include in the FAQ's.
Post pics (side and front views) of your rig and title what brand & size tire you are running and comments about them. There is ongoing questions about tires and I think visual reference will help people out. This way, you can just scroll down and see everyone's tire combinations. Help everyone out. :steer:
I'm running 265/75R16 with a 2" OME lift
295/75/16 BFG All-Terrains. 2" lift upfront. 2.5" in the rear FYI
I like them, 9K on them and showing no wear. Only issue is the side lugs get ate up after a while from full lock turning. Don't vent mud to well, but when dry I have endless amounts of grip. Slight rubbing on the frame at full lock. And just found out they rub on the inner wheel well while resting on the bump-stops upfront under extreme flex.
Nitto 285/75/R16...Great on road...minimal noise but does not have strong side walls. I already had cuts(sidewall) on two of them...Will not buy again.
