I have a revtek lift 3" with size 33'' MT tires and 18 " wheels was wondering if anyone knows if I could go 34 or 35 size tires Is it possible? would I have room?
Do you think I could go 35/12.5/18 on my revtek 3'' lift and have enough room?
I guess I would have to cut and weld my body mount to avoid the rubbing, and to move up to 34" or 35" cause right now with 33" I'm getting a slight rubbing on the driver front side...
I'm running 33/12.50/18x10 open coutry MT made by toyo tires I realy like the look on these tires...and they are pretty quite as well..My wheels size is 18x8..What tires are you running currently. I only ask because I have not seen tire rub with my 3" kits, I would like to try some of the tire you are using. Can you measure the tire's actual height as well.
Thanks,
Michael
I'm running 33/12.5/18.9 open coutry MT made by toyo tires I realy like the look on these tires...and they are pretty quite as well
Yes they are 18'',but on my reciep it said 18x8.Ok, I have not heard of this the diameter of the tire is 18.9 inches?? is it considered an 18" wheel? Have you off-roaded with 18" wheel yet. I wheeled with 17" wheels for the first time recently and felt I would rather stick with 16" for wheeling a little more sidewall to give.
Cheers,
Michael
I have off road it and it ran great, no problems at all...
why? is he not happy with the 35''?35s? Why, a well balanced rig does just fine with 33", 3"lift and trimed body mounts to max articulation. DirtBoss has 35s ask him.
