idk guys,
mine is dead nuts every time. when i built the motor and buttoned up the distributor, i guessed at where i thought "perfect" would be. it fired up the first time, it was on, dead nuts. havent moved it since.
while i agree there is some "slop" in the timing system with backlash of all the gears and chain and what not, when the system is in motion, all of that goes away. meaning, once it starts spinning, the slop comes out and the gears are loaded in one direction the whole time its spinning. so it should be consistent unless you unload the gearset and change directions of rotation. (which is really bad in the sense of an engine lol)
i dont know if that explanation was clear, but my point is whether the timing is right or wrong from what you read, it should be the same every time the engine comes around.
imagine if you had two gears in a mesh. if you hold one still and try to spin the other one it will "jiggle" back and forth in the space between teeth. this is the backlash. once you let go of the gear and it starts to spin the backlash effective comes out of the system. one tooth makes contact to push the gear and before it rotates out of the way the next tooth makes contact. so as long as its under a spinning load, the second gear should have no "wiggle". if you do, either something is really worn, or you have the wrong size gear for the mesh (in a theoretical sense, not actually on your truck nerdnoise. just an example)
thats just my opinion
