Timing Cover O-rings
SmokingRocks
hopelessly addicted to Cruisers
Colorado
Can't find any O-Rings in my seal kit that fit the timing cover. There are three O rings, two can be seen here the third is a rectangular O-Ring that is on the bottom side of the water pump housing. Napa doesn't have the right sizes, was thinking of checking car-quest, will also call toyota this morning but I can't find any part number call out either.
you will be hard-pressed to find anything that betters the OEM material, if it existed then Mr. T would've spec'd it.
Good luck, let us know what you find.
I'm looking for a new material so it won't get brittle in the future.
If you don't mind, I'd like to ask you the same question i use to ask some of my customers, and never got a good answer. If said part isn't broken, damaged, or causing a problem, in this case these O rings. Why on earth would you want to spend time, and money on replacing them when you know the factory ones worked for well over 100 thousand miles?
