KlausVanWinkle said:Do you need to replace/rebuild the entire starter? I thought it was just the Starter Contacts that were known to fail, causing the starter to fail.
When I say "rebuild" the starter, I mean the two contacts and the plunger.
Follow items would be my personal list if I owned a Hundy:
16100-59275-83: water pump
13568-09070: timing belt
90916-02586: serp belt
13540-50030: belt tensioner
96761-24019: housing oring
96761-35035: housing oring
13503-0F010: belt idler
13505-0F010: belt idler
90311-A0001: crankshaft seal
90916-03100: thermostat/oring: 16346-50010
Based on inspection, replace the following:
Upper and lower hoses
Radiator cap
Rebuild/replace starter
Fan clutch
Flush radiator
PCV valve and two vent hoses
Clean throttle body
Clean manifold assys
Replace intake manifold gaskets
Air filter
Oil filter and change
Replace vacuum lines as needed
Some other sundries here and there....
Rough price estimate (since im not at work): MUD pricing: ~$650-700
Great info, this is a private sale. needs tires, needs center muffler, 60000 miles and we are at my offer of $17000 and after a lot of back and forth there price is at $17550 came from southern NY seems pretty rust free but
What you all think?
daninghram said:We are guessing it never got run long enough to dry out the inside of of the muffler. out looked not bad but falling apart. Everthing else seemed to look good but flashlight failed before I looked through the whole thing.
Zero (for the pre-VVTi rigs).
Zero for the later 2UZ-FEs.
GaFJC said:Zero.
Ugh.
Aside from the valid thought of replacing everything when you're in there - have we been duped into replacing the t belts? I can see the water pumps as most of them in 4.7's leak (per PowderPig).
Regardless, if you are doing a water pump it would be stupid not to do the timing belt too.
Just to reiterate: my list is a list of thing "I" would do. Im slightly more anal about "while-you-are-in-there" maintenance.
What you all think?
