this might be a slick set up
Gig Harbor WA
Not a bad deal at all, I think someone down south would do well picking up the combo.
Only short comings of the toyota lockers is the course spline which takes a half second longer the ARBs.
Wow, that actually is a good deal. Did you notice the front already has spring over pads? Or are all 60 fronts like that? I already have all that plus disks in the rear. BUT, I have 5.29 ring and pinions and they are to low for my diesel engine. So, I'm going to buy two 4.11 difffs with cable lockers from G&S Cruiser Parts and then sell my 5.29 diffs.
TB
yeah all the front axles are like that (pads) but its still for a sprung under set up..its only about a 2 inch square that your spring would sit on if you used them...
on the front, I think thats where the U-bolts mount for the SUA stock set up....brain no worky today
but if ya got a stock axled 60/2 this is alot of bang for the buck, no need to set up gears and lockers, a FF to boot and OEM cable lockers with all the parts needed.
Wish I had a need.......or do I?
Of course you do. You cruiser poor bugger you.
You dont need me pointing that out now.
TB :P :beer:
not really, I have ARB in the rear of my fj60 with 4.10 gears. If I didn't have that I would be all over this set up. the 62 doesn't need lockers, the 60's axles won't fit under anything else I have....
so no I really don't need em..........want em sure ;)
[quote author=HZJ60_Guy link=board=29;threadid=17744;start=msg171904#msg171904 date=1086801372]
TB :P :beer:
[/quote]
Why wont they fit? I dont get that. Shouldnt they bolt right up under most of your stuff?
Your 60 could use that front cable.......
You can never be too locked up. Unless you are on show and ice and then you can just pull the cable, flip the switch.
TB
Where do the levers mount?
where the sqaure drink holder is now.
yeah I suppose with some mods they would fit under a 40/5/55 but they will be wider than the stock axles.
[quote author=Jman link=board=29;threadid=17744;start=msg171996#msg171996 date=1086808973]
In my truck . . . :D
[/quote]
Roger doger.
TB
