- Joined
- Mar 12, 2008
- Threads
- 67
- Messages
- 1,887
- Location
- El Salvador and Washington, D.C.
- Website
- www.facebook.com
I was discussing my rebuild with a co-worker who is rebuilding his twin engine aircraft. We are actually doing many of the same things the same way but without consulting each other. When I mentioned to him that I was about to get the Painless kit he asked if I either had the original harness or a diagram of the OEM harness. Not the wiring diagram for the vehicle but the diagram of the harness. He was able to get one for the harness for his plane and is going to take the time to rebuild the harness, wire by wire from scratch using almost all new parts. While time consuming and alot of effort I love the idea. I have the time to kill while the body shop beats the dents into submission and hand sands everything down to the frame. To even consider this I can see two issues and I'm hoping that one of you guys can help me with. First, I need a diagram of the actual loom, i.e., the harness itself, not the wiring diagram for the truck. To do this right I think that I would do it like the old school factories did it. I get a diagram of the harness, blow it up to real size, tack it up on a plywood board and then build the loom wire by wire, connector by connector, branch by branch, physically on top of the blown up diagram. As each section is done, lay it over tacks on the board to hold it in place per the underlying diagram. Repeat process until each section is complete. At the end I should have the whole thing layed out on the tack board over top of the life size version of the diagram, just like the old school factory process. Bundle up each branch take it off the board and install per the vehicle wiring diagram in the FSM.
As such this is a non starter unless I can get a diagram of the OEM wiring harness. Additionally, I need a source for reasonably priced OEM striped wire. I just got the new catalog from Waytek and they say that they will do custom striped wires so I'll start there. I am interested in all suggestions for sourcing wire and the harness diagram. I had originally budgeted in the rebuild for the Painless setup. This project only makes economic sense if I can bring it in at or below that figure.
Under normal circumstances the fall back to no harness diagram would be to pull the existing wiring harness from the rig, tack it up on the plywood and re do it. Those of you who have followed my build thread have heard this rant, can't be done cause the the PO mercilessly fawked it up. Suffice it to say, there isn't a branch of the original harness that is intact as OEM, they have either been cut and spliced with whatever was lying around, wrong colors, different gauge wire or the wire just dead ends and never reaches from the switch to the item , e.g. horn, windshield wipers, oil temp gauge, etc. Honestly, I'm hoping that one of you is as big a pack rat as I am and somewhere along the way has snagged the harness diagram at a flea market and just has it stuffed away on a shelf gathering dust for awaiting its turn in line for some future project.
