Some strange happenings with my fresh 1HD-t. I've out 1500kms on the new motor now and have had a strange noise from the get-go. It sounds like a rotating noise, a scraping as though the fan was hitting the shroud and is very consistent with RPM's, it doesn't change when hot or cold and doesn't seem to affect performance. It seems to be coming from the lower portion of the timing cover but it is really hard to pinpoint- at times it sounds as though it were coming from under the valve cover.
Things I have done: removed all belts to isolate water pump/ alternator. Pulled inspection plate at bellhousing- nothing odd there, no filings, etc.. Changed the oil through a strainer- not a thing for the magnet to pick up. Pulled the T-belt cover- small amount of belt dust but nothing obvious that would create a noise like that. Removed the harmonic balancer and inspected- looks normal w/ no evidence of rubbing. Pulled the vacuum pump. I'm not quite sure how tell if one of these is healthy- this one seems to create vacuum but when turning by hand several revolutions will be consistently smooth and then followed by a couple of hard turns. Also, my brakes have been acting funny intermittently- like they are applying themselves and sticking on. Could this be related to the vacuum pump?
I've removed the glow plugs and have turned the engine over by hand but nothing is jumping out at me. I hear the clicking from the IP and I think also from the injectors but I'm not sure how those components should sound. Next step will be removing the timing cover- I'll have the it torn down to the short block at this rate!
Any, ANY ideas would be welcomed. Sorry for the book...
