Hey gang - Still having issues and could really use some additional suggestions... Here's the situation this morning:
1) I drained about a cup of coolant out of the radiator bottom drain valve due to the problem I had yesterday (coolant started to overflow with radiator cap off, per Tare's procedure above). 2) Engine warmed up to about 186 degrees, coolant started to overflow AGAIN out of the top of the radiator.
It appears that the new t-stat never opened because the level never dropped? Also, when I was replacing the fluid yesterday after replacing the t-stat, ~ 10 cups came out of the housing into my bucket (there was additional that absorbed into the rag I used to plug off the hose coming out of the t-stat housing), so I actually put a little bit less back in then what came out.
Suggestions???
Suggestions???
