what is the correct temp?
if you are getting a coolant temp CEL code it is usually your O2 sensorsI went to local orielly’s and they showed two thermostats. 170* and 180* so I assumed since my code was coolant. It not hot enough it should be the 180*. I just bought this lx and thought PO just put the wrong one in.
Most people here recommend to only use Toyota parts for everything. I am not in this camp. There are some parts that I would only go Toyota while others I will go with a non-Toyota part. Toyota isn't the only company that makes good parts and many times I can buy the same part without the Toyota name on the box for 1/2 the price.Most people here recommend to only use the Toyota part, not aftermarket.
I just did mine and went with a Aisin thermostat for $14. I've had Cruisers for 35 years and have used other thermostats like Stant as well. I've never had an issue myself.
Bingo.In my opinion, this part lies at the intersection of critical and inexpensive.
