Builds The Volvo C304 restoration.
Work has started on the rear FRame see the arrow
The kitchen area layed out with 4 boxes. The farest away box will be a slide out draw for the cookers.
The cockpit with the air cond unit under the passenger front
The pilot seat with the mockup dash sitting in it. It will all be lifted about 50mm and the left side about 100mm during the rear dash makeup.
looking good Cicak , thumbs up from Denmark
Sorry no PORTAL PICS. I'm waiting for the local mechanic to put his into his LC II so I can get pics for you currebntly the PORTALS are away getting the DISCS fitted.
More in 2-3 weeks when im back up there and the "roofrack" is meant to be all tacked together to view and the new RADIATOR should be here from the US of A.
and the GREEN/BLUE wagon ran faultlessly including a run to the lake to take me for a 2.5 hour kayak my first since I left hospital 2 months ago and a overnight camp by myself. So im back training for my 400k solo trip in October.
Over the weekend - Saturday I arrived at the workshop 11.00am and left 4.30pm
We discussed over 5 hours so much stuff
1. I sat in the pilots seat and we put a seat in and sorted out the DASH position and what it will look like - next time I go up a blank new DASH will be made which will allow any control to be reached while wearing the harnessss seatbelts. sinx im 6' 2" it has to be correct for me and the SHORT friends who will drive it. as it is a small very cockpit and we are not changign thelayout at all.
2. We discussed at length the new pipe bending machine (the quality of the bends is unbelievable not one crease) and the location of all components of the "ROOF RACK" the KAYAKS have to fit somewhere and the design completely including position of LED LIGHTS hanging off it. After watching a MAN DIESEL in the BRESLAU and a few VOLVOS (all cabovers) I changed the location of the LED light rack to on top of the roof as all VOLVO''s go a long way into the water/MUD on entry - oops (usually up to the bottom of the window). The whole roof rack will be tacked together in 2-3 weeks ready for my viewing.
3. The LED lights will allow FLOW of air over the roof to the RADIATOR scoop and INtercooler SCOOP.
4. The positioning of recovery kit was decided and including the highlift JACK and shovels etc
5. I cut and fitted the rear cabin panel then we looked at it and BRett said I can make it easier and nicer we use the new alloy composit material - he showed me and im hooked 3mm thick and LIGHT as and easy to work and even easier to clean and it will lighten up the CABIN - same for REAR CABIN also. The outside of the rear cabin will also be same material means I do not have to paint it - colours we are thinking of are GREEN or RED or bright PINK .
6. All electrics apart from the WINCHES and the STARTER and alternator will be 12Volts a 12V alternator to be fitted soon - I will now proceed to order all the parts slowly there is a list of about 30 items to be purchased - List later im still flabergasted after I starting writing it out
7. The rear cabin will be totally ALLOY protected by the "ROOF RACK" - man it will be light I estimate under 100kg. It will also be prepainted as it comes in COLOURED allow so all I have to do is pick the colour I like (BRIGHT YELLOW) and thats the final lCOAT . Then the cabin has to be paited to match only. Saves me about 2-3,000 in painting the rear inside and out.
8. 1 Month has been allocated to do the wiring alone.
9. Position of everything inside the cabin worked out Wiring BOX will be on the roof and flip down and a full length console for securing stuff. Air conditioning controller already installed.
10. Radio and VHF will be on the roof.
11. KILL switch for everything will be in reach of both PASSENGER and PILOT.
12. Rear floor will be wait for it a PLASTIC FLOOR - LIGHT 10mm thick and everything proof - it comes from NZ and is for CHEMICAL cabinet making More on this one later.
13. We discussed painting and underseal and soundproofing. Once the cabin is finished it will be removed and sent to Kuala Lumpur once I find a place to underseal it here. Then take it back to IPOH (it may even be painted in Kuala Lumpur first also since we only have to colour match it to the rear external panels). Then the internal soundproofing can be installed and then the alloy finishing and the fitting of the dash and the overhead consoles and the wiring can be completed.
That's perfectly ok, Im in no hurry right now :-)
20-07-2012
Got to visit the Volvo (C304 4x4) Saturday. It was in pieces again after 8 months of inactivity they started work on it last monday.
Cabin one side of the shop. The new 12v battery box sitting in the front and another to be made beside it.
Through the rear panel into the cabin.
And the chassis on the other side
The Engines mounts redone so they can be unbolted.
The 12v Alternator is being mounted in reverse on a bracket so it faces back to the engine as there is no room for it to actually sit on the engine.
The new radiator built for a hot rod from Summit racing in the USA. If you think its big is 18" wide by 31" high
The final pic is the BUGGY look.
Another visit in 3 weeks when the exo cage is built.
Really cool resto. Are you aiming for an overland type vehicle?
I am aiming for a cross between a DAKAR truck and a serious JUNGLE truck and for touring a nice quiet cabin which we can just jump into the hammocks at nite and sleep or beds depends on our moods.
Lets see when it is finished
Awesome! I'm really starting to like these things, especially the 304.
04 September 2012
Yay progress
The external cage/roofrack is taking shape.
The front view still not complete.
Side view
The rear tray floor frame is also taking shape.
The Radiator on the left and the intercooler hanging in place on the right will be the exhaust.
more pics soon as I get to sit in it Friday and we look at how to set the 14 gauge dash out (VDO gauges) and make it all waterproof plan to make the whole instrument cluster sealed in a box with only one wire hole or a series of holes on one side only later siliconed up.
Friday 7 September 2012 went up to see the Volvo
The dash layout with actual size of instruments and layout.
The layout and the dash and the steeering wheel
Trying out the position of the Dually LED light for the front side facing positioning.
The harness seatbelts holder between the two windows and they are anchored to the floor.
Side view the rollcage is now attached to the rear of the cabin in 3 spots per side. They started out to be removed now they realised they needed them to add rigidity to the roll cage.
The position of the exhaust (almost in the spot) the radiator (fan to be added), the intercooler (to get its own fan) and air cond unit.
The rest of the next two weeks will be spent fitting everything around the rear of the cabin sealing it all up and isolating the radiator from eveything else, positioning the highlift jack etc inside, intercooler connected up with the correct size piping , radiator connected up etc and all the other recovery gear ready to then start the rear cabin.
The exhaust is to go out over the roof and yes it will have one of those cute little flaps which lifts up. Im so excited about this.
After XMAS is the next best finish date now.
Next visit I do not know fully booked with Tourism Video shoot and 3 weekends in a row of 4x4 work.
New shocks purchased AMADA's new PIGGY back shocks.
Valved for a 80 Series Landcruiser they should almost be correct we will correct once its on its feet and driving.
FYI $2800rm or $913USD for the set of 4 shocks.
Still no estimate of completion date may be end of February 2013.
Visited the Volvo in the hospital yesterday no pics the light at 5pm in the workshop through the skylight just made taking pics impossible.
1. Shocks fitted for a test and removed the REAR piggyback will hit the Springs and the other way too round too easy for bamboo or a vine to wrap around the wheel and tear the piggy back off. Piggy back down also impossible things will hit and tear them off. A quick call to the AMADA shock shop and they will convert the rears to REMOTE for me in a few weeks. Wonderful
2. Put the wife in the passenger seat realised the floor needs to have a 50mm platform as her feet not touching the floor resulting in loss of circulation
3. Fuel tank inspected after builder consesses to making it 1.5mm ALLOY and not 2 or 3mm so its now an experiment we will 1/2 fill it (140 liters) when the truck is finished and drive and see if it bursts open - oooooooooppps.
4. Wife inspected the proposed composite material for the outside and gave it the thumbs up
5. Work resumes on 15/1/2013 when the builder finishes the order of 15+ military trailers
6. CHecked everything else on the truck all seems to be progressing ok. Cabin rollcage is complete.
7. More pics in 3 weeks time when I visit the hospital again.
No progress for almost 9+ months
He too busy doing trailer orders military and others and problems with workers turning up 5 days a week
Last week he finished automating some of his production line.
He said he would personally start work on it this week (25th March) as he dropped by last weekend on his mountain bike when I was working on my equioment shed near his workshop (30k away) to give me a progress report.
