Well, found another dumbass move one of the POs had done, the outside O2 sensor on my '92 is WELDED ON!!! Not only that, but it looks as if someone tried to grind it off, failed, and tried to reweld it.
I now have a slight exhaust leak that is just enough to aggrivate, a welded O2 sensor, a fuggered up bung, and other headaches that will be addressed later.
I was curious about what the average cost to have a new downpipe with bung made would be, and what size pipe I should go with (would replace both and cats w/ high flow if I do this)? I have 2.5 exhaust from the Y-pipe back, should I stick with the 2.25(?) or go to 2.5" Or should I keep the down pipes stock size, and go with a single high flow cat?
