Hey everyone! I'm new to mud. Talked to a few of you and realized I would like to share my build with you all. This is the first time that I have posted anything like this so bear with me. This build is not done yet but getting pretty close. Maybe by the end of this build thread it will be done. Well as done as a build can be. They are never really done are they? Much of my inspiration for this build has come from a lot of you all. I bought my 1994 80 series about 7 years ago. I had wanted one for a long time. By the time I was able to get one they were fairly old trucks. I picked this one up for $2100! Has 265k on the odometer. It ran and was rust free. Very rare for the east coast. I am located in Virginia. I picked it up in Richmond Va. about 2 hours away from home. Obviously it was going to need some work but I love to restore vehicles in my spare time so I knew a little bit of what I was getting into. Or did I? In this build thread I will cover how this rig came to be and how it evolved into what it is now. I have had a little bit of everything as far as off road rigs go from my 1964 CJ5 Kaiser Willys (which I still have) to a 1999 Jeep Cherokee XJ with 8 inch lift, 35s, and the works. But now onto the Toyota goodies.
1994 Toyota Land Cruiser
Factory lockers
Things done:
-Custom 3 link front suspension
-Radflo 14 inch travel coilovers with reservoirs and compression adjusters up front
-Radflo 10 inch travel shocks with reservoirs and compression adjusters on rear
-2.0 Radflo bump stops up front
-5 inch OME competition coils on rear
-Custom bump stops in rear
-Cut and modified fender wells/flares
-Front axle truss
-Front knuckle gussets
-Slee off-road brake lines
-Slee off-road belly pan
-New calipers and rotors/pads (including emergency brakes)
-Longfield chromoly axles in front
-1 ton steering conversion
-5.29 Nitro gears and bearings
-Metal Tech adjustable upper control arms in rear
-Iron Man pan hards front and rear
-New bushings and bearings most everywhere
-Binks Fab front bumper
-4x4 Labs rear bumper with swing out
-White Knuckle off-road sliders
-Method NV 305 17x8.5 wheels
-Trail gear 2 inch wheel spacers
-Mickey Thompson Baja MTZ P3 40x13.5x17 tires
-Huracan Fabrication tailgate storage
-600 watt pure sine wave inverter
-Rockville 8 inch subwoofer (inch factory sub location)
-2.5lb Clean angent fire extinguisher
-Aisin lock out hubs
-Part time 4 wheel drive (homemade will eventually buy actual kit)
-CDL switch with 7 pin mod
-Low/High range lever extension
-New u joints in drive shafts
-New Toyota radiator
-New Toyota heater core
-Pesky heater hose mod
-Rear heat delete
-New front main seal
-New oil pump seal
-New distributor o-ring
-New Spark plugs
-New air filter
-Yellow Top Optima Battery
-Custom rocker switches for off-road lights
-USB ports with voltage gauge
-Alpine ILX-107 double din head unit
-Cobra 75 WX ST CB radio
-Seat heater controls
-Extra fuse panel added under hood
-Blacked out grille
Things to do:
-Rear main seal/arch seals/oil pan gasket
-Powder coat/paint bumpers and sliders
-Front seat upholstery and seat heaters
-LandTank seat extensions
-Winch (Smittybilt 12k synthetic rope)
-Hella Led off-road lights on bumper
-Rear Led lights in bumper
-New Toyota power steering pump
-Toyota power steering hoses
-Derale Heat sink cooler for power steering
-Paint exterior of truck
-New window rubber runners (hopefully help windows go up better)
-New exterior window trim
-New fender flare rubber
-Mount full size spare
-Mount Hi-Lift Jack
Wish list:
-Hydro assist steering
-Prinsu roof rack
-DRIVE THIS BEAST!
Factory lockers
Things done:
-Front axle truss
-Rear heat delete
-New oil pump seal
-New Spark plugs
-New air filter
-Blacked out grille
Things to do:
-Mount Hi-Lift Jack
Wish list:
-Prinsu roof rack
-DRIVE THIS BEAST!
