HI everyone,
The frame on my 1987 FJ 60 is at the end of it's useful life, and it is ready to be reclaimed by mother earth! It has been repaired twice already, and rust holes have started to appear in new places. Also the rear channel is totally ravaged by rust, aka the "wet cardboard" look. There is no hope for this frame!
With the above info in mind, I picked up a new rust free frame a few weeks ago. The frame is in great shape, even the rear channel in nice with just a bit of surface rust. I do need to find a rear crossmember however since it is missing on this frame because there was an aftermarket bumper mounted.
I found a shop to swap my frame, and his quote to do the job is $1, 500. Before I have the frame swapped I want to protect it in the best way possible, so what is the best way?
Powder coat?
Paint?
Galvanizing?
I like the look of powder coating, however there is no logical way to clean and powder coat the inside of the frame rails. The same issue presents itself with paint. As many people have noted, the Land Cruiser frame rusts from the inside out. I would hate to go through the trouble of a frame swap, only to have it rot out again.
So that leaves galvanizing. However there seems to be many variables with galvanizing as well. I noticed that there are may threaded holes on the frame, so I guess sacrificial bolts would need to be put in place? Also are the holes on the frame enough/large enough to allow to zinc to drain out? I have contacted three galvanizing places here in NJ, two places say the frame MUST be sandblasted first, and the third place does not care (Home Hot Dip Galvanizing and Protective Coatings for Steel from Voigt & Schweitzer and New Jersey Galvanizing).
The frame still has the original Toyota paint on it. The price difference is also large, the two places that want it sandblasted said it will cost "around" $300.00, while the third place claims about $800.00. I am also concerned with painting after galvanizing. I called a good powder coating place in NJ, and they feel that powder coating does not stick well to galvanizing, and they claim paint does not either. Is there truth to that? I would like the frame to be painted or powder coated black after the hot dip process.
So what do you say? What experiences can you share? The biggest concern for me is inside the rails.
Thanks,
Zack
PS: Does anyone have a good rear crossmember for my 87?
Powder coat?
Paint?
Galvanizing?
Thanks,
Zack
