- Thread starter
- #561
And there is a new radiator coming, but I did not order it when finding a leak a the seam on top.
Now understand that seam leak = replace
Tested the old and new coolant with pH test paper, no color difference, try to stay above pH 7
Water has a pH of 7.0 and antifreeze has a pH of 10.5, so a 50-50 mix has a pH of 8.75, and that’s too acidic to protect the cooling system.
The pH value is a way of expressing the relative acidity of coolant. Acidity does cause corrosion.
How to test for electrolysis
The radiator is leaking, started slowly and the power steering belt was making noise because it was slipping from the cooling liquid!
Then I drove 3000 km while adding water at every fuel stop (no problem)
But now it is leaking a lot, a small puddle when driving and parking so it is now not drivable anymore.
New radiator is ordered and I will start removing the old one.
EDIT: new radiator was not in stock so repaired the old one with melted tin. pressure test was ok at 1.8 bar an no air bubbles when submerged in water.
Red is a vinegar test strip:
immediately mentioned to buy new: we don't want to get stranded but I was stubborn
) and sold the big one.
