That Moment When You Want to Puke: Trying to finish HG job.
Flank
American by Birth, Texan by the grace of God.
Flower Mound, TX
Website
www.staltimber.com
About 2 and half years ago (give or take), my 17 year old daughter totaled my Gen 1 Sequoia that was my company truck. My 95 cruiser was pulled into duty as my daily driver, making deliveries and pulling trailers. The box trailer I pull often was too much for it, too slow on the highway, had me worried. I found a new Gen 2 Sequoia for e 5.7L after about a month and was able to pull the Cruiser off of duty. About 3 days later my wife said the cruiser stalled. That's weird. I got home and checked it out and found white smoke pouring out of the exhaust. Well... Crap. Blown head gasket, but no overheating. Did my research, I parked it, changed the oil, and it sat for 2 years.
7 months ago, I finally bought all of the parts for the HG and upper end job, and tore it down, sent the head to the machine shop to get checked, decked, valve job, etc. I finally got the time to get back into it about 3 weeks ago. Plan was to finish it this weekend. I've been going by OTTRAM's incredible videos, as well as the FSM for the journey.
I repaired bad plugs in the wiring harness last weekend... Today was installing the upper intake, exhaust, TB, basically finish up stuff. The the fateful words in OTTRAM video #4 "Oh, don't forgot to connect the throttle body water hose to the block." Easy when it's out out of the truck, but buried and a bugger when it's in the truck, right above the rear knock sensor.
I unpluged the knock sensor connector and worked to get the hose attached and hose clamp secured. In my no-look reaching and struggling from under the truck , I heard something plastic hit the concrete. I looked over and saw the knock sensor connector plug on the ground next to my head. Crap. Queue rage induced nausea...
NOW, figuring out if I can get a pigtail on the plug to fix it, or if I tear off the upper intake again to get to the wiring harness to repair... I guess it will come down to whether or not I can deconstruct the plug today without destroying it. Several of the fuel injector plugs got destroyed trying to reclaim them and I replace them with new OEM.
You can splice in a pigtail for the knock sensors without pulling the intake. Post #93 in this thread Anyone recognize this 80 - https://forum.ih8mud.com/threads/anyone-recognize-this-80.1355924/page-5 has a link to Ballenger for the proper pigtail with connector. On the rear knock sensor, pull the front tire and go in through the wheel well. The front knock sensor wiring can be accessed from the top. It will be tight but it's doable. I was able to snip wires, strip wires, crimp wires together with a barrel connector, and finish up with heat shrink using a heat gun. Doable, not fun, but much better that stripping the intake.
Not understanding. Did the knock sensor break or the connector that attaches to the knock sensor?
It's accessible from the top for sure. I had to pull and reinstall my main engine harness in the yard. Everything still attached.
The sensor wire connector broke off - apparently weak after 30 years... The front can be had from the top, the rear requires going in through the wheel well. I'm not stressed about getting power to the wire on a splice. I'm more worried about making it water-proof / resistant.
Knock sensor connector - https://forum.ih8mud.com/threads/knock-sensor-connector.1277597/
If the pins are still good, you can depin it and put the pins in the new connector.
If it's the top of the knock sensor, that's a little bit more expensive to fix. This happened to me. When trying to put the connector back on the front knock sensor, it snapped right off. The connector on the wire going to the sensor was fine. I had to replace the knock sensor and it was close to $250 at the time.
89615-60010 Toyota Land Cruiser 1FZFE 4.5L Engine Knock Control Sensor OEM
So what's gonna happen is....:
I bought a finished plug pigtail and gonna see if I can satisfactorily get it mated and waterproofed through the fender (reminder - Rear sensor), if not to where I'm happy, the upper intake comes back off so I can pull the wire up and get it from the top side. Wish me luck. Will post back next weekend.
:meh:
:meh:
Good luck!
Murphys law loses every time...
Eventually
:meh:
Good luck however this may be impossible. If I remember correctly, the engine harness is tied in such a way that the runs to sensors has very little slack. I don't think there's enough slack to pull up the wire and make the repair. However, I would much rather try the repair through the wheel well rather than pulling the intake manifold.
^This.
Just replace the connector housing. Splicing a new pigtail is overkill.
