test results propane injection on 1997 HZJ75
crushers
post ho
Derwent Alberta
test unit:
1997 HZJ75
turbo
variable propane injection
35" good year ATS
open diffs
3" lift
factory engine
factory cab
H55F
4:11 gearing
test trip was 5800 km long including mountains, desert, long grades. elevation from sea level to 7200 ft.
test results:
17.6 mpg 70 mph Calgary Alberta to Fernie BC strong head winds
19.4 mpg 70 mph Ferni BC to Sandpoint ID some steep hills
?? misplaced ?? Sandpoint ID to Preston WA long steep hills and flat terrain
17.5 mpg 70-85 mph Preston WA to Redding WA a lot of long steep hills
23.6 mpg 65-70 mph Redding WA to Woodland WA flat
16.8 mpg 70-80 mph Woodland WA to Folsom CA flat and fast
23.7 mpg 60-65 mph Folsom CA to King City CA flat and slow
16.3 mpg 60-65 mph King cityCA to Pismo and back flat and slow and abused on the beach
?? misplaced ?? King city to Folsom CA flat and slow
16.8 mpg 70-85 mph Folsom to Battle Mountain NV some good long hills
16.9 mpg 70-85 mph Battle mountain to Jerome ID flat with a few long hills
13.2 mpg 70-85 mph Jerome ID to Idaho Falls flat with strong head wind
16.7 mpg 70-85 mpg Idaho Falls to Boulder MT long gentle and steep hills
i used 2 X 20 lbs tanks of propane from Calgary to Fremont CA. one tank was not fresh when we departed from Calgary. there is still Propane in the 2 tanks from the return trip. the truck ran with out a hitch even though pushed quite hard during the test. trying the truck with out the PI and it felt sluggish once the PI was turned back on it was a pleasure to drive.
in the entire trip i used 2 litres of oil.
i hope this helps anyone that is curious about the advantage of PI. considering the speed we were driving and the size of the tires the fuel milage return was impressive. the propane added about 3 mpg but more important than that the driving experience was comfortable.
if anyone is interested they can contact me direct and i will supply any answers that i can.
cheers
Wayne
www.luxuryimports.ca JDM imports
www.crushersrule.com restorations and trip reports
speed kills-live forever- drive a Toyota
That HZJ75 pulls better than an intercooled 5 speed HDJ80 I have to add. Did you ever weigh it, Wayne?
Dave
Dave
i never had a chance, been running my feet off. i will try and get it weighed one of these days and report back.
cheers
Wayne
Stone said:
Thanks for the info, Wayne...interesting. Any brilliant ideas on where to store two 20lb propane bottles in a BJ74 without it looking like a Getaway Van? Cheers.
i am getting a bottle built that fits underneather the body on a BJ74 and HJ61.
this will be a 30 lb and will have a custom skid plate also designed for these units. these will mount beside the driveshaft and attach to the frame for strength and peace of mind.
of course they will have a remote fill...
cheers
Wayne
VTCruiser said:
nice, whats the setup? custome? kit? how much does it cost if you don't mind me asking?
it is a setup specially dialed in for the cruisers. the boost comes on where WE need it. also the propane in injected at a variable rate so the power comes on smooth and does not suddenly load the engine.
the kit is $649 american and the bottles or tank is extra.
to be completely honest i would not do this for the sake of gaining a couple miles to the gallon but when you couple that with the performance and egt drop then it makes great sense.
i will be installing these setups on all the LJ71s that i have coming in. this will give the little 2LT the power increase that is needed. they really are a great little truck but deffinately not the greatest power house on the planet. once i can get the horsepower up over 100 and at the same time keep it reliable then we have a win/win situation.
cheers
Wayne
cheers
Wayne
Wayneo, will that bottle fit under my HJ60?
If so Im in!
TB
Afternoon TB,
it should fit like a glove.
when do you want it?
cheers
Wayne
Well, it all depends on when ole Rob can get me my 60 back!
HA!
In the next month or so Id guess.
Is there any point in your opinion to PI a NON turbo'd vehicle?
I dont have a turbo yet.
TB
HA!
TB
waste of time and money, this setup only works off boost presure. once it is turbo'd then you can be up and running strong.
get Rob to ship the truck here after he is finished and i can custom install the turbo and PI and you can fly in and speed home...
cheers
Wayne
