History:
* Jim C Rebuilt Carb 1.5 Years ago
* Head Redone (Burnt Exhayst Valve) 1.5 Yrs Ago
* Running Good
* 50/50 Mix Gas and E85 at (Current) Test
Smog Test Results (Current)
Test 1st Idle / Precondition * / P-Standard / Final-Idle / Idle Std
HC ppm 1826 / 389 / 300 / 1485 / 400 Fail
CO ppm 0.09 / 0.10 / 3.00 / .13 / 5.00 Pass
* Precondition is Running it on the Dyno at 30 MPH for a Minute. P-Standard is the Limit for that test.
Smog Results - 1 Year Ago (100% Gas - No E-85)
Test Final-Idle / Idle Std
HC ppm 391 / 400 Pass
CO ppm .48 / 5.00 Pass
Is there a correllation between the E-85 and the extremely low CO?
Is there a correllation between extremely low CO and the extremely High HC that can be "balanced"?
Today, I plan to:
1. Tune Up (Air Cleaner / Verify Timing / Plugs)
2. New PCV Valve
3. Compression Check (Dry and Wet)
4. Change Oil
Ideas appreciated.
Rocky
* Running Good
Today, I plan to:
2. New PCV Valve
4. Change Oil
Ideas appreciated.
Rocky
