Techstream error- will not read AHC and other tests
Just looked up the issue and looks like I have a bad height sensor in addition to the high pressures.. I'm going to order new springs and crank on the torsion bars...
Thanks everyone for chiming in and hope no one else runs into this issue.
SUCCESS..... after all this it was the cable... man was that annoying... turns out both the rear and fronts were reading 10+ pressure. Also have a copy code.. front wheel speed sensor signal error. Anyone know what this is? Experience.
Clear the error code and see if it returns. You had your front wheels straight when you read your pressures?
Sent from my iPhone using IH8MUD Forum
Both (front and back) at 10+ reading?
Your '06 rig is quite young. My logic tells me that both front and rear would have different readings, not same numbers. Unless TBs were really loosened out over time and the springs has gone very saggy.
Did you start the reading from L to N (height control)? And like PADDO said, clear the code. This may be the culprit.
Yes. They aren't the same reading exactly. I have the ahc override and diff. Drop. I only moved the torsion bar bolts two turns on each side. it seems like the front has had trouble staying up. Suspension goes up and down fairly easy and had correct fluid movement last time it was check. I did go from L to N. I will try to clear the code.. yes the front wheels were straight. I thought I read the AHC springs last about 7 years. My rig has 130 k mostly highway miles. May have seen some towing also. I bought is when it had 120 k.
Readings of 10+ Mpa front and rear are pretty high for a stock height/weight vehicle. Your not confusing the height accumulator reading (usually around 10.5Mpa) with rear are you? And how did you determine a height sensor was defective, you can expect a few mm variation between the fronts. FWIW I'm still on original coils at 135k miles with 15mm spacers, my rear pressure has finally crept up to 6.7 so I'll be changing them out soon.
No. My accumulator was 10.5. So that was in spec. So I didn't confuse them. I got an error for the front sensor.
What change did you see when you said you've cranked TB's two turns? Should have at least gone down with your readings? Have you checked whether your 30 mm bolts are within spec? Then start from there. Check out --https://forum.ih8mud.com/threads/adjusting-torsion-bar-with-ahc-questions.677799/#post-9261286 with post #9.
I tow few times a year but not too heavy on the tongue though. I also have teenager passengers (sometimes 5 or 6) in the back quite often. I'm at 6.9 for the rear. 146k and still with original coils.
I cranked them before checking the pressure so I'm not exactly sure. I didn't check to see the bars were within spec. I will do that. Thanks for the information. I think it's good for everyone to have data points on usage of the ahc and durability.
An update. I replaced the right rear globe with a functional used globe. Did a full ahc drain and fill and swapped in the springs. I also cranked down on the torsion bars.....Man were those way off!. After all these things the front pressures seemed to be perfect. The rears however would stop working correctly after going into high... after much deliberation and explicatives I decided to pull of the spare as there was some rubbing on the rear suspension bar.... things seemed.to be working perfectly after this for a 150 mile drive and then all of a sudden I start getting the harsh ride from the rear again. .
This has been happening intermittently now on start up. Sometimes the truck will register L. And after a few minutes of driving the suspension will rise...
.... The rears however would stop working correctly after going into high... after much deliberation and explicatives I decided to pull of the spare as there was some rubbing on the rear suspension bar.... things seemed.to be working perfectly after this for a 150 mile drive and then all of a sudden I start getting the harsh ride from the rear again. .
This sounds like a height sensor malfunction. Intermittent.
I was thinking that it was an electrical problem so I'm glad to hear that you also think so.. will a bad height sensor also cause a poor ride? The vehicle seems at correct height even though it reads L.
Ok. Thank you! I'm going to sort this out this weekend.
X2. Height sensors have finite life spans. Check the linkages are free and not bound up, you can open and clean the contact surfaces within too to buy a bit more time. If a height sensor is sending spurious feedback to the ECU while in motion you may well be getting random leveling signals to the front or rear resulting in increased pressures that are making the ride more harsh. Set your vehicle to N and turn off the AHC, it will stay off and won't try and self level while you drive, as long as you are under 50mph. You will still have damping control with AHC off but without the self leveling and height feedback. This may help to isolate the problem back to a failing height sensor. Above 50 mph it will turn itself back on and do its leveling thing. As uHu pointed out, any random or intermittent height/leveling issues and you should suspect a height sensor issue.
Little hi-jack ....
Went on Ebay/Amazon to purchase Tech stream to get involved and found many versions. :bang:
With pricing from mild to wild.:bang:
:confused: will all the choices
V7.xx.xxx
V8.xx.xxx
V9.xx.xxx
Whats a non tech brother to do???:meh:
Thanks
