Techstream error- will not read AHC and other tests
Update- pulled the rear sensor and that thing was toast! Two springs were rusted and came apart. One of the tabs was completely eroded away.. Switched it with another one and everything seems to be workin smooth. I'll post up my AHC data. For those in wet climates I recommend changing out the old O-rings.. They are too smal IMO...
Fr height- 0.9
Fl height- (-1.2)
RR- (-.1)
Front pressure- 7.3
Rear pressure- 7.7
Accumulator- 10.5
Also getting an error c1713?
Do the height sensors need to be the same or does the system adjust.
Fr height- 0.9
Fl height- (-1.2)
RR- (-.1)
Front pressure- 7.3
Rear pressure- 7.7
Accumulator- 10.5
C1713 is a fault with your rear height sensor and if your units of measurement are set to inches (as opposed to mm) you need to get those fronts closer to zero, say within .2 or so - that's assuming your on level ground. Your front and rear accumulator pressures are too high, crank your TBs to get the front closer to 6.9 so that's 2 full turns on either side. New coils for the rear.
I just installed new LC coils. I'll crank down and adjust the TBs. Report back soon.
Yes. The AHC coils
