Tech Questions Here (13 Viewers)
is there a vent on the gas tank? I'm sure there is but I have no clue where it would be.[/QUOTE
if said tank has only a single fuel line & no other fittings then it must have a vented cap
if it has two fuel lines AKA supply & return then in can use a vented cap but most prob has some kind of vac vent system.
to help in locating vent need the following .
?#1 what kinda gas tank
?#2 is it on a vehicle or some kind of equipment
?#3 what is the appx age of #1 or #2
Answer to all qustions. My 1981 toyota Landcruiser FJ 40
Not sure the layout on the 81 Corey the 77 & 78 models have a vent system that flows through the charcoal canister. Also has a little plastic coil vent right above the gas tank filler on pass side. My 70 had a vented camp and no charcoal system. I'll look to see what else I can find. :)
Thanks for the link it will help me build a smaller manifold than the one I am using now.
No problem. Thanks for the parts today!
I have searched but have not had much success in locating a 5:28 ring and pinion re-gear for a 97 FZJ-80. Does anyone know who sells the best set out there? Thanks.
Go to 80 tech and to search, type regear, you'll get all kinda threads.
It would be a 5:29, don't go with the Sierra's I have.
Slee has Nitro but only go up to 4:88's
Slee - Drivetrain - Gears and Lockers
TPI sell the Precision
TPI4x4
Anybody know if you can make a 2nd gen tire carrier fit a 1st gen 4Runner?
Not sure on that one but as Albert puts it everything is Doable :D you would want to weld in some reinforcement metal on the inside of the rear quarters so when you bolted it up it wouldn't peel back the metal on the trails. I thought about doing the same with a factory 80 carrier but I need the bumper carrier for the extra stuff.
Yeah, I was thinking it should work with some fab work. I almost expected someone to come back with a reason why it was impossible.
nothing is impossible with enough desire patients time materials skills and of course ----------a bit of mula :hillbilly:
of course, can't forget the mula
I forgot one friends in high places:lol:----does anybody have the new # for the White House cause when I try I get a message "no longer in service"
I hear that. I'm in a low place where I am afraid to even check my oil!
