yep there is no going back now! he has his own fleetWe're gonna have to come up with a club member of the year award for youYou're a good man I'm glad you picked the Toyota side of the fence even if its was your second choice
igot the new adjustable bilstine shocks for the front the fj any body knows wher i can have them put on ? i dont have coil spring compreser to undo it and dont wanna take my head off i needa get it done for the ride!
I swapped mine at Pepboys for something like $20 a pair, pull your old ones off and bring them along with the new ones.
tx for the infoPaul,
This article touches on what were talking about yesterday. The front 8inch high pinion 3rd out of an 80 will fit.
Toyota Axle Upgrade Guide - Brake Upgrades - 4 Wheel Drive & Sport Utility Magazine
The website I was telling you about.
Erik's Toyota Differential info
I was able to change my outer pinion bearing and seal today. The noise has almost gone away but you can still hear it a little at higher speeds. I don't know what else it can be but its definitely getting better.
Go with two switches the man in front of you might give you theany sugestions on wiring the top lights one switch are 2? i know they are 35 watts but it dont say and amp draw ,on the lights what size fues should i run if u go single switch 20 amp ?
I have a 66 FJ40 and a while back I installed a weber carb on it because the original carb was beyond repair. The weber 32/36 seems to work great when it comes to starting, idling and slow acceleration but when it is under heavy acceleration its a whole different beast. Heres my problem, when I try to accelerate quickly and I mean pedal to the floor as quickly as possible the engine will almost die like it is either getting to much fuel or not enough. I did notice today that my electric choke is fully open all of the time and if I would hold the choke about half way closed and then accelerate quickly the engine seemed accelerate much smoother and didnt quite act like it wanted to die. I live in lafayette and if anyone lives in the city and is familiar with carburetors I beg you please help me out. I have a hard time explaing the problem so it would be easier for someone to actually hear it. I think I possibly may have to re=jet the carb but I am really just guessing at this point.
Thanks in advance
-Cruzersoul-![]()
yep that.s what it sounds likeIt sounds like a jet issue which has been known to be an issue on some webers. Shipped with the wrong jets. Paul tracked down some good info a short time ago on them while running into the same issue. I'm sure you checked but do you have good fuel pressure from the fuel pump? Old factory mechanical pump could have a leaking diaphragm. I think I still have one off my 67 if you need it. We have our monthly meeting at Buffalo Wild Wings this Sunday 1 - 3 p.m. it would be a good time to come out and say hello. If I'm able I'd be happy to take a ride over and look at it for you.
Some good info.
https://forum.ih8mud.com/40-55-series-tech/213147-***weber-carb***-adjustment-thread.html
