- Thread starter
- #901
Anyone have a press that I could use to press some bearings? Should take long.
None here sorry
I do need to add one to the shop though.Follow along with the video below to see how to install our site as a web app on your home screen.
I do need to add one to the shop though.Yep but is down till Monday or Tuesday waiting on a sealAnyone have a press that I could use to press some bearings? Shouldn't take long.
what bearings are ya`wantin to press?No, I won't have anything besides the carrier and the bearings. I think I am going to be able to use one in the maintenance shop at work. If not I will get back on here again. Cajun Offroad is the only place out of the ones I called that could do it but they said it would be 2 hrs of work at $70 per hour.
well then don`t need a press for those just a dial mic to set te lash.I haven't tore into it yet but I am pretty sure it is the differential bearings. The ones that sit under the bearing caps in the diff.
:whoops: my badshouldn`t post after being in the sun all day.
as I stated my press is down till next week due to a seal can rig ya up with a similar puller.
again apologize fo -da- mis information![]()
anyone know the fuel pressure on the 3.0 v6
Ok guys, I can't even get my bearing caps off without a vice. I'm SOL and it looks like I am going to have to take it to a shop to have them do it. Right now I'm pretty stressed about it because the 4Runner is my daily driver as well. On top of all of that, I not getting to go offshore right now so my money is drying up.
Does anyone have a shop with a vice that I could borrow this weekend?[/QUOT E]as stated before ya gona need a bearing puller to remove the cones press to install cones then need dial mic to set back lash of the R&P to as close to .006 as possible.
ps am assuming you are just changing the carrier bearings and not the pinion bearings if changing all will need to set depth of pinion as well ya be doing the axle bearings/ seals?o-rings?
Give a call or P.M. me your number I can find you a vice and a press this weekend if needed for your third member.
You're a good man I'm glad you picked the Toyota side of the fence even if its was your second choice
