- Thread starter
- #541
yeah ya'll automatic people suck!! lol! i sure wish i had a automatic runner. (so i could take the kids and not work so hard)
I posted a nice 2000 4-Runner I saw on the LA4x4 board. You sell that Tot-Hoe yet?
O.K. got the brakes bleed and working on the 85. I am having NO luck bleeding the clutch. Start from the top new clutch cylinder, new slave cylinder. Pulled the bleed screw from the slave cylinder filled the reservoir full and tried to gravity bleed the system. nope no fluid coming after a few hours . Tried to prime and bleed the system by pumping the clutch and holding and cracking the bleed screw at the slave cylinder. No air or fluid seems to come out the slave cylinder.WHAT am I doing wrong?
... Note to self brake fluid burns in cuts on hands.. I like my auto![]()
remove line at the clutch master this be a two person job .O.K. got the brakes bleed and working on the 85. I am having NO luck bleeding the clutch. Start from the top new clutch cylinder, new slave cylinder. Pulled the bleed screw from the slave cylinder filled the reservoir full and tried to gravity bleed the system. nope no fluid coming after a few hours . Tried to prime and bleed the system by pumping the clutch and holding and cracking the bleed screw at the slave cylinder. No air or fluid seems to come out the slave cylinder.WHAT am I doing wrong?
ME?---am always UP early on last cupman look at that post time!
how much coffe have you had this morn?![]()
nah up and attem gotta max out these next few days before i hit the workin stiffs schedule.
meetin the riot this morn to grab me sis'scomputer.
3/16 will work as long as you use metric line nuts if the line lock is US then use us to fit lockanyone know the size of the toyota brake lines. I see a line lock in the near future
YEP !! HYD clutch SYSTEMS are real KISS systems ------------------ but sometimes can kick ass ---- in my humble opinion think there are of the female gender LOLThanks all !!
Disconnected the metal line and blew compressed air through it till it was coming out the other end. That is where the problem was that line was plugged. Then used a syringe(left over from Thanksgiving used on the Turkey) with a rubber hose attached to the metal line by the master cylinder and filled full of fluid till it was pouring out the other end of the line by the slave cylinder. Then connected to slave cylinder to the line and removed bleed screw and primmed slave cylinder and reinstalled bleed screw.
Did the two man job of primming the master cylinder and reconnected metal line and bleed the entire system. Work great got a good petal and decided to bleed just one more time and lost everything..... Ran out of brake fluid
in master cylinder even though I was warned about it. At least we had practice .
All is good the clutch works , truck now stops and theis looking at it just shaking here head
. It's still a gem in my mind.
So I'm at work, daydreaming....I know my suspension needs something changed. I still don't know if it is shocks, springs, or both. I know i can't push the front end down unless I get all 250lbs of me up on the bumper and jump.
I'm thinking about removing a leaf...I read up on it and I guess all I need are some C-clamps so i don't kill myself, and a prybar to get the metal band that keeps them lined up off. Does this sound about right?
Anyone ever done this? Any reccommendations?
edit. The 350 is lighter than the 2F, and the springs were for a FJ40, so I'm pretty sure they are stiffer than they need to be.
