Thanks for the advice Cole. Everything went smoothly. The front went quickly and smoothly. I had so much travel, that I only needed one floor jack. I even had enough stock brake hose to leave it connected...in fact, the old springs practically fell out, and the new springs went in easily...I didn't even need the coil spring compressor that I bought. The rear end was trickier, because I didn't jack the frame up high enough...finally put the Hi-Lift on the rear, got it higher, and had to disconnect the sway bars, and brake line bracket. The I was able to drop it. There was LOTS of room everywhere. Installed shocks, steering dampener, etc.
Notes: I like the differential axle breathers on the 80 series ALOT. I would like to see if they fit a 40 series. I'll add some length to them when the snorkel goes on.
My stock tires are so TINY. It's hilarious. There is a tremendous amount of travel in the 80 suspension already. I've read lots about what folks are doing to increase theirs, but I don't think I'll need any more than what I saw today unless I go to Arkansas or Moab.
Test drive and first impressions: Drives like a dream. Old shocks weren't shot...they were still okay. Stock suspension was just to bouncy. I was worried about steering and driveline vibrations due to all the threads I'd read about. I had none of these.
I have the castor correction kit, and plan to have these installed later this week. I want to drive it a few days to "see" and "feel" the difference. I also want to actually MEASURE my castor and see what I have first. I don't see how someone can "know" what you need. Each rig is different. Also, I looked at Man-A-Fre's drop bracket kit, but its just a couple of pieces of flat steel that you bolt on (or weld)...I think they're out of their minds charging hundreds for that. I took a drive around in the rain...handles great...rides great.
I left the center caps off, as I kind of like the way the solid full floating axles look. May just leave it. Stopped raining, I'll go take some pics.
