Hi,
I did trany swap(H41 -> H55F) and T-case rebuild at May 2005.
But I did a mistake when reassembling t-case that it can't operate as 4WD mode.
Only operates 2wd high and low.
I suppose the point which I did mistake is front drive cluth hub and sleev.
I'd removed front shaft to change bearing.
Mine is non-usa FJ62 with manual trany with vacuum shift that has 4wd lamp at dash but it's always on without pressing button.
Front shaft rounds freely with or without pressing 4wd button.
My guess is, clutch sleev can't move front and back freely and it always on the hub that front shaft can't operate with clutch hub.
Anyway, to solve this problem, I plan t-case work.
I have a few experience about removing trany/t-case work such as clutch job but it's very heavy work that I'm considering about t-case work on vehicle.
I don't have trany jack now that must doing work without proper equipment so I'm thinking like this.
'Without removing trany/t-case, removing rear drive shaft and disassmble t-case and doing work.'
It's my scenario
Are there any member who have experience about this ? Is it possible and enough plan ?
If yes, could you please share technique and experience with me ?
Any kind of suggestion is WELCOME.
Oh, Min Seok
It's my scenario
Oh, Min Seok
