T-case thread sealant
Back in Vegas
On my split t-case the PO used some sort of thread sealant on all of the bolts. it appears to be a silicone that stays tacky and is sor tof an aqua blue in color. he also used it on many of the gaskets. This stuff worked real well but I cannot find it anywhere, any one have any ideas as to what this stuff is?
The FSM calls for thread sealant on many of the bolts but does not specify a type. In the past I have used RTV silicone with mixed results, what do you guys use that will keep your t-case tight just like it came from the factory?
It is most likly a product called Hylomar (spelling) it really good stuff.
Dynosoar
Fawk if I know...
I just used plain old blue loctite on the bolts and lightly lubed the gaskets.... so far so good no leaks after sitting for 12 hours :eek:
Mace.... that trans jack adapter kicks ass!!! fit perfect on my jack, the best $25 spent at harbo frieght!!
Did you never use it???
It is a lifesaver when you need to move a auto around...
Or a big pig of a 6 speed ferd tranny..
