Doesn't t bar behavior have less to do with diameter and more to do with the way the steel was made?
*Diameter
*And the fact they have a more limited range of motion. Meaning:
If you have them set for no lift...the range where they twist is about even, up vs down travel. Ride is better and you're within their "twisting" range.
If you have lift then they twist very little when the tire droops. When the tire needs to be compressed they have to twist far more than normal. Outside of their normal range of motion they "fight back" as though they were progressive (though technically they are not). This is another main reason why you can't strap on a long-arm front suspension and expect 12-inches travel. The bars have to go too as they cannot allow that travel.
