Can anyone tell me what the best weight synthetic line is to run on my '98 4runner winch?
Its a Warn M8000. Not sure the length. Probably 100 feet or so. I usually wheel in thickly wooded areas in Mississippi. The muddles can be tricky. Pulls are usually fairly short.
Where is that avaialable?For a Warn M8000 go 3/8" x 85'. We splice our own winch lines in house and offer MUD discounts.![]()
How do you attach that to the spool?This the kind of thing you're talking about for m8000 folks?
Southeast Overland Synthetic Winch Line Extensions : 3/8" Southeast Overland Amsteel Blue Winch Line Extensions | Southeast Overland
I have a warn series 12. I put 75' of 3/8" amsteel blue from Steve at southeast overland. My thoughts are the same as half k' s, less line equals less line to pull out to get max power on pulls. I have 75' worth of extension.Here's something to put on your radar. Just because the spool will take 100ft of 3/8'' doesn't mean you need to put that on there. For my recent purchase I shorted my MM hydraulic by 20ft of line. I then purchased a 50ft extension if I ever need it. The thought behind it is with 20 less feet of line i'm already down one additional wrap towards the drum. Since I don't have actual numbers in front of me lets just say my initial pull would be 8500lbs instead of 6750lbs. That's if it was a short pull only off of the first wrap. Anything more and the advantage would be even greater.
