What advantage is there to syn grease?
I went and got some Amsoil HD moly grease for the newfileds.
I was lazy and didn't take apart the steering knuckle and clean out the dino grease out of the knuckle bearings. I did clean out all the grease from the birfield part of the knuckle though.
As the steeings bearins don't do much other than move back and forth, slowly. I don't think there could be much damage to the bearings if the grease doesn't mix. It doesn't look like the grease should mix much anyways.
As the birfield takes a lot of grease, the frozen grease(when its cold out) might turn a bit easier. But does syn wheel bearing grease make any difference?
