Hey guys. I did a solid axle swap on my '02 Tacoma using an FJ80 front axle 4-5 years ago and it has been holding up great. During this time, I've now broken my 8" rear Tacoma TRD diff for the 3rd time. I really did not think it would break again because it was cryo'ed, professionally setup and I added a trackbar. I obviously cannot keep replacing these and decided on an FZJ80
diff (for one thing, it would match the front). Been doing a lot of searching and found answers for most of my questions, but still have a few, so would really appreciate any input. This is my DD, so the rear upgrade has to work both on the Hwy and off-road.
1. The FJ80 rear diff is off-centre, so my options are to:
a) have it re-tubed to get the diff centered. Sounds like an easy solution.
b) swap my centered T-case for an FJ80 off-centre T-case. I'm currently running dual gear driven T-cases. Does anyone know if there is an adaptor to add a crawlbox in front of an off-centered FJ case?
c) get a Diamond axle housing for the FJ80 diff, etc. Sounds like the most expensive option.
d) just run the off-centered diff with a double carden U-joint on both ends of the driveshaft. Would this work without any vibrations on the highway? Anyone doing this? Any pro's and con's to the above options. Any suggestions or input? Any options I haven't thought of (apart from other types of axles)
2. I've just invested $2000 + into my 15" rims, beadlocks and tires, so would not like to part with them yet. When, I did the SAS I swapped the rotors and calipers from a '91 FJ onto the '95 axle to fit the 15"rims. I would like to go with an FF setup w/ disk brakes but keep my 15" rims. Can this be done? The rims I have are the AR767 style steelies with the 3.5" backspacing IIRC. Are there parts, say mixing and matching from other vehichles that can make this happen? Or would I be stuck with drums and a semi-floater until such time that I go with 16 inchers and do a conversion?
OK, I think that is it for now, and I apologize for asking because I'm sure this have been covered before, I just couldn't find it. Gary.
