Here's what I believe Nay to conceptualize
WE:
I think what you aren't keeping in mind is that both rods are flat, as in horizontal to the frame. What that means in terms of how you got there is irrelevent to arc. Nay is speaking to 'effective' lift" as being the same in terms of frame drop mount" or lift axle mount
Here's how I interpreted his meaning.
LG = LB
<G = <B = horizontal
Pivot Centerline of G = Pivot Centerline of B
Axle Centerline of G = Axle Centerline of B
Then, as you can see:
Arc of G = Arc of B
Your geometry assumes to much. Remember, we are only speaking to "Effective" lift in either scenario causing the axle to be horizontal. You are assigning that an equal value to both scenarios. That's not assumed, nor calculated. Nor does it matter really, because Nay is speaking to effective lift vs clearance.
As such, you would have the following as your arcs (See picture in post 98).
Cheers
SJ
WE:
LG = LB
Arc of G = Arc of B
Cheers
SJ
). The issue is articulation restriction, and interference restriction caused by the raising of the front pivot point.
