Resurecting to ask a dumb question. Shocks, sways, brake lines, or binding...which limits front articulation on a stock Cruiser?
spartan said:Don't you guys know the man in the avitar - clue - Black Flag.....I'd be willing to bet Tyler likes a little head banging now and then....
IBCRUSN said:I can certainly see that the OME shock setup is less than ideal for any of their lifts.
IBCRUSN said:Nay & WE,
I see what you're getting at. IIRC AJ moved his upper shock mounts for just such a reason.
http://www.actionjackson.com/cruiser/mods/20041231.asp
Walking Eagle said:I'd say that the OME shock set-up is less than Ideal for any of the taller slee or MAF lifts. But they're fine for the OME lifts. When you start throwing spacers on top of the J's, you've gone outside of what the J's and L's were made for.
Nay said:I agree on the L's, but I'm not sure on the other lifts. OME uses the same shock on the stock height kit as they use on the heavy kit. That's up to 3" lift difference with the same shocks....so whether you are stock or a 3" lift, you can't go up in tire size (and OME doesn't design for that on a base kit because presumably you'd need gears). Seems you could adjust the shocks to get 35's to fit.
Walking Eagle said:It's kinda like the difference between Slee's 4" kit and 6" kit. The shocks are the same, and the bump stops are the same, all that is really changing more up travel, less down travel.
Walking Eagle said:Actually Slee’s site it says
"OME850J/OME863J coils and N73L/N74L shocks should be installed together, although they do not comprise a kit. Fitment of N73L/N74L shocks requires mandatory installation of .75" (20mm) Front and 1.25" (30mm) rear bump stop spacers to the front and rear suspension to prevent shock absorbers from bottoming out under full compression. These bump stop spacers are not available from OME and will need to be sourced from the installer."
So, lifts that use L shocks and 2” blocks, leave an extra 1.25” of compression on the front shock, and .75” in the rear.
