Wanted to drop in with update.
I did the installation yesterday with my father in law, the OME shocks and springs are in! But, not without difficulty.
Prework - went smooth,
- KDSS valves were free of rust, removed shield, and loosened no problem. I bought a 5mm 3/8 hex bit from SK tool, it fits perfect, but was probably not necessary.
- spc control arms went toghether easily with good instructions
- marked alignment cams with paint marker (proved to be useful)
Rear suspension. starting at 10am we had LC lifted and wheels off.
- rear went together without drama. Needed to use a pipe wrench to hold shocks. 22mm swivel head ratcheting wrench was the ticket here.
- used @TexAZ ‘s method. Worked great. I was able muscle the KDSS and sway.
- we were feeling good, and took long lunch at 12:15pm
front suspension - starting about 1:30pm
first problem, how to get the stearing connection off the spindle? hit it with brass punch? Nope. Put nut on hit it? Nope. Used pitman arm puller shown above at a strange angle? Yes! This worked, but took an insane amount of force! With the tie rod off we had to spend about a 45 mins chasing and cleaning up the threads on the tie rod end, to clean up our mess. What is the best practice here? It was a pain!
- removed LCA > spindle bolts, loosened the LCA aligment cams (loosen nuts/bolts on forward side)
- remove sway bar on LCA
second problem Install OME coilover, clearanceS are tight to get the shock bottom into the LCA, the shock bottom was not exactly 90 degrees to the 4 top bolts had to loosen top shock bolt to adjust. Resulted in a lot of knuckle mashing and exercise. Check this first!
third problem - while supporting the spindle with a jack stand and popping the uca taper, it realeses with force, our wire tie was not tight enough, the jack stand didn’t support it enough, our us wrestling the LCA back onto the spindle, we over extended the ABS wire on the passenger side. Didn’t figure this out until we started the LC to start on the other side.
- onto the UCAs, again following @TexAZ ’s fantastic process recommendation, unthreading he top bolt is super tight, you have to unclip hoses and the factory washers are so tight, they really work against you here. You have to use extreme patience here, time consuming effort. On the driver side you have to remove the battery, but it’s the easier side.
- wrapped the passenger side, just in time for 6pm dinner
4.5 hours to do the passenger side
- 7:15 staring on driver side. Much smoother, still had challenges getting tie rod off the steering linkage, pitman puller to required a s***load of force, but worked without damage threads (please share the recommended was to do this)
- buttuned up the drivers side at about 9:15 pm and we were feeling pretty good. At this piont we only three things left to do, LCA alignment cams on the ground, front sway bar and put on the tires
fourth and biggest problem - reattaching the front sway bar to the LCAs was the biggest bitch of all time. We tried everything! Jacking up the LCA, ratchet strap, loosening the sway bar attachment bolts, hanging like a monkey from the sway bar. It was impossible to get the round bushing to line up so the bolt could line up. We spent 90 minutes without progress. Then, we stumbled this method (
What's the trick to reinstalling stabilizer bar links? ) and got it done. That is a fantastic tip. You are man
@619TOY ! Get a tight fitting 6 point socket long extension and just muscle the bushing where it needs to go.
- wrapped up at about 11pm with a huge mess in the shop. Took us about 9.5 hours
The drive home was short, but the alignment was magically spot on. felt good, but looking forward to a real test.
Still need to do an alignment and remedy my buffet of dash lights.
I’ll come back though and a more detailed review.
Thanks again!
