sunroof problems
I know this has been written on many a times!
but man I cant find where the dang drain tubes come out ???
I know somwjere by the front mudflap but I have looked and looked to no avail :doh: !
a photo or exact gps location for these tubes would be great!
thanks :D
You will not find the end of the tube's they empty into the rockers and the water comes out of the rockers at the bottom. Open the sunroof and pour some water in the drains it will become clear to you
IIRC in the front you can't see the ends. When I poured water in the top of the tube, it came out from a slit in the rocker panel back, IIRC. I suggest you do just that to see where the water comes out and ensure that all is well (not plugged).
edit : WTH? RT beats me by a few seconds.... :D
more edit: great minds think alike!
yep, what is really scarry is I was about to say the same thing :eek:
i know they are both clogged due to seeing the fluid in them with the kock panels off. So how do you us ethe zip tie method to clean if they are unreachable in the rocker panel?
it's because goin' through the headliner experience makes one part of a small exclusive elite...
OMMMMMMMMM!!!!!!!!!!!!!!!!
