Hi all. Long time mud member but rarely visit this forum.
My wife's 2010 200 series that we've had for 7+ years recently exhibited symptom similar to those described in this thread:
forum.ih8mud.com
What's different is that while all the 'dash lit up like a Christmas tree' symptoms were the same and the motor seemed to lock up once, it billowed white smoke out the exhaust like a blown head gasket. Not too long back, the main drive belt broke, and looking back now, I'm guessing she overheated it..which led to the demise of the head gasket and potentially other/worse things. At this point it seems to be hydro-locked and the local techs think it's likely too far gone as the coolant has sat in the cylinders for a few weeks.
I guess I'm looking for some feedback on the following questions:
Does anyone have any thoughts regarding the current prognosis...is it too far gone and not even worth pulling the heads at this point? Asked another way, is an engine swap about the only option if one was looking to get it back on the road?
Assuming an engine swap is the best option, are there any documented cases of someone swapping in a Tundra/Sequoia based 3ur? Availability of a 200 series based 3ur seems low...and hard to trust as evidenced by the thread above. I saw early on in that thread where someone posted a link to some high performance replacements, but, from what I could tell, those were tundra based 3ur's.
If, for me personally, it's not worth throwing more money at, is there any market for it as a parts/project truck. I know a value can't be put on it without pics detailing the general condition etc, but anyone willing to put a ballpark figure on its value as is (assuming it's a clean example with 250k ish miles)?
Thanks in advance for all the feedback.
JT
Death of a 3UR
Initial info: 2014 and 15xxxx miles. Oil level good and just hit 5k oci and was set to be changed. Drove fine on mix of interstate and secondary roads until parked. Wife reports that as she parked it developed a rough idle just before turning off. Will not start after. Several jump attempts...
forum.ih8mud.com
JT
