Suggestions for Bump Stops
I have a 2.5" OME J lift on my truck with Man-A-Fre 30mm spacers on the front. I have not modified or replaced the bump stops in the front or rear. Any suggestions as to where and what type of bump stops to get? I was thinking that i could at least fabricate the rear bump stops myself, but don't know how big to make the spacers. I figure that it would be easier to use pre-fab stops for the front. I am currently running 305s and not experiencing any rub. I would like to make it so that I can run 315s without any rub.
Suggestions, comments, questions:confused:
Bump-stop height is usually dictated by the compressed length of the shocks you are running or the tires. It depends on what hits first. With that much lift I would assume you are using extended OME shocks. If so, it usually takes a spacer of about 1.5 inches to prevent bottoming the shock. As you already observed, the 305's do not rub. I believe that 1.5 to to 2 inches will keep 315s (on stock off-set wheels) from rubbing. You do not want more of a drop than absolutely necessary because that will limit your over-all travel even more.
D-
D-
You are right with the extended shocks. So you mean that i will need to extend the stock spacers an extra 2 inches? If I fab my own, it will be stock spacing, plus two inches?
Thanks,
Andrew
With extended OME shocks you will need to have whatever bump-stops you choose 1 and 1/2 to 2 inches lower than the stock bumpstop position to prevent the shocks from bottoming out when the suspension is fully compressed.
I just used 2.5" 1/4" wall square tube. It's about perfect with the J spring rear and "L" shocks.
posing for Tyler...and I didn't even lift a tire :D
Great pictures Ben! What did you do in the front? I am going to fab the rear spacers and 2.5" sounds good with that setup. What size tires are you running?
Any more suggestions for front spacers?
Thanks,
Andrew
Oh and is there any extra back spacing on those wheels?
Thanks,
Andrew
So far nothing...:rolleyes: I have Slee 4" springs up front and "L" shocks and still haven't come to fully compressing them. That being said, I'll prolly do the same thing, fab up a bit smaller sqaure tube, prolly 1" 1.5" Again I haven't seen it come close yet with the 4" lift to bottoming out..
I'm running 35X12.50X15 Trxxus M/T's on the stock wheels.
